Database Transaction Helper
RunDbTransaction
RunDbTransaction is a fluent helper for running safe and clean database transactions in Laravel.
It handles edge cases around rollback levels, especially when using custom exceptions like DefaultException (common in our codebase).
❔ Why This Matters
When a DefaultException is thrown (one that already performs a rollback), using DB::beginTransaction() with a try-catch around it can lead to double rollback errors or broken transaction levels.
That's the main problem RunDbTransaction solves:
It detects if rollback has already happened (e.g. inside
DefaultException) -
Prevents Laravel’s transaction level from going out of sync
Lets you catch and handle exceptions cleanly — even continue without rollback if needed
It also works great with regular exceptions that don’t trigger rollback on their own.
⚠️ try - catch - rollback issue
public function run()
DB::beginTransaction();
try {
$this->transactionBody();
DB::commit();
} catch (\Exception $e) {
DB::rollback(); //ISSUE: in case of DefaultException this causes over rollback!!!
private function transactionBody($value)
if (!$value) {
throw new DefaultException("Missing value!");
return $value
When DefaultException is thrown rollback is triggered by itself and DB::rollback() inside catch() {...}over rollback the transaction and rolling back all your current work! While rollback is still needed when normal exceptions are thrown!
RunDbTransaction is here to solve that !
✅ Basic Usage
$successful = RunDbTransaction::create()
->transaction(fn() => $this->mainTransaction())
->run();
Always call
run()at the end. -
Returns
trueif transaction was committed. -
Returns
falseif it was rolled back.
⚙️ Methods
→ transaction(callable $callback)
Defines the main code block that runs inside the transaction.
->transaction(fn() => $this->doSomething())
→ intercept(callable $handler)
Optional. Runs only if an exception was thrown and rollback hasn’t yet happened.
This is where you can handle something like DefaultException, and still choose to commit the transaction.
->intercept(fn($e) => $this->handleBeforeRollback($e))
Return truthy value → Commit happens
Return falsy value → Rollback proceeds
→ catch(callable $handler)
Optional. Runs after rollback. Even if intercept ran but returned false.
->catch(fn($e) => $this->handleAfterRollback($e))
🚀 Full Example with All Handlers
->intercept(fn($e) => $this->interceptException($e))
->catch(fn($e) => $this->catchException($e))
->run();
🧪 Force Rollback Manually
You can force a rollback by returning a special flag:
$committed = RunDbTransaction::create()
->transaction(function () {
$this->doSomething();
return RunDbTransaction::DO_ROLLBACK;
->run();
Returns
false -
No exception handlers are triggered
Transaction is rolled back cleanly
🔁 Shortcuts
RunDbTransaction::runTransaction(fn() => ...)
Basic one-liner with safe rollback handling:
$success = RunDbTransaction::runTransaction(fn() => $this->mainTransaction());
$success = RunDbTransaction::create()
->run();
RunDbTransaction::runOrFail(fn() => ...)
Same as above, but rethrows the exception if one happens and allows it to propagate further. When you only need managed transaction block:
RunDbTransaction::runOrFail(fn() => $this->mainTransaction());
Also works with DO_ROLLBACK – in that case it rolls back without throwing.
Also shorthand for:
//This shape is required when intercept handler is needed!
->catch(function ($e) {
//handle catch here
throw $e; //rethrow exception to propagate further
->run();
Use this shorthand when you want error to propagate further and only need save transaction block.
💡 Summary Table
| Method | Description |
transaction() |
Required. Code block to wrap in a transaction |
intercept() |
Optional. Runs if exception is thrown before rollback |
catch() |
Optional. Runs after rollback, always gets the exception |
run() |
Executes the transaction logic |
runTransaction() |
Shorthand with rollback detection |
runOrFail() |
Shorthand that rethrows exception |
DO_ROLLBACK |
Special return value to force rollback without exception |
🧱 What About Nested Transactions?
RunDbTransaction also handles multiple levels of transactions safely — something that can easily go wrong if you're using raw DB::beginTransaction() and DB::commit() in deeply nested code.
Laravel supports nested transactions using savepoints, but if you're not careful, breaking out early or not committing the right number of levels can mess up the whole DB state.
function transactionBody() {
$startLevel = DB::transactionLevel(); // e.g., 1
DB::beginTransaction(); // level 2
if ($something) {
DB::beginTransaction(); // level 3
// do some work...
return; // who commits both levels? RunDbTransaction DOES !!!
If you would fin yourself in such scenarion in the first place.
Its smarter to nest RunDbTransaction blocks
