Sql Recursive Loop Check
SqlRecursiveCheckTask
SqlRecursiveCheckTask helps you find loops in data where one item points to another — for example, parent-child or dependency relationships.
It checks for cycles, like when A → B → C → A. These can break trees, graphs, or dependency systems.
What You Give It
You can give it data in two ways:
1. Query Builder or Eloquent Builder
Pass a query where you select exactly two fields:
from_id: the starting point -
to_id: where it points to
Example:
Model::select('id as from_id', 'parent_id as to_id')
2. Array or Collection
You can pass an array or a Laravel collection of pairs:
As named keys:
['from_id' => 1, 'to_id' => 2],
['from_id' => 2, 'to_id' => 3],
['from_id' => 3, 'to_id' => 1],
Or just plain arrays:
[1, 2],
[2, 3],
[3, 1],
What It Does
It runs a recursive SQL query to find all loops — meaning chains where something eventually points back to itself.
This is useful if you want to prevent circular references that could cause bugs or infinite loops in your system.
What It Returns
It returns a list of found loops. Each loop is shown from the perspective of each node inside the loop.
Output format (same as DB::select):
"root_id": 3,
"path": "{5,8,3}"
"root_id": 5,
"path": "{8,3,5}"
"root_id": 8,
"path": "{3,5,8}"
Each item means:
root_id: the node where the search started -
path: the full loop path it found (as a string like a PostgreSQL array)
