Update work position
This action requires the "update work position" permission.
Through the update form, you can manage:
- Name and international title of the work position:
- If the work position does not have a different international title, it can be the same as the name.
- Leave bonus:
- Set the amount of extra leave days that employees with this work positions get.
- Parent work position:
- Set which work position this is a subset of (used when a work position can be present in multiple departments)
- When this is the case, one parent work position is created, and then work positions for specific departments are derived from it.
- Is parent:
- Set work position as a parent work position. Only work positions with this option checked can be selected as parent work positions.
- Mars code:
- HR department:
- Work positions need to be linked to HR departments in order to be assignable to users.
A work position must be connected to a HR department in order to be assignable.
When a work position is moved from one department to another, you can set the "To" date on the old department link and add a new one. The new one will then automatically become active.
Active links to departments must have the "To" dates set in the future.
